milehighpeter
#1 Posted : Wednesday, April 6, 2011 10:52:14 AM(UTC)
milehighpeter
My waher fills and washes ok but will not automatically go to the spin and drain cycle....I can manually advance to the spin and drtain cycle, then I also have to manually advance it to the off. The washer has been working perfectly, and is just a month over a year old but was moved from one house to another and this just started after the move????:(
#2 Posted : Wednesday, April 6, 2011 2:03:11 PM(UTC)
Open the control panel and check the timer wire harness plug connection.
If there is nothing wrong, replace the timer.
- The timer Part number: AP3995038
milehighpeter
#3 Posted : Thursday, April 7, 2011 6:27:47 AM(UTC)
milehighpeter
Thanks for your help...the plug is fine...I will order the timer...Peter
#4 Posted : Thursday, April 7, 2011 11:49:00 AM(UTC)
You are welcome Peter. Keep us posted.
