recky64
#1 Posted : Monday, October 27, 2008 3:47:36 PM(UTC)
recky64
I recently replaced the belt. The dryer started making a squeaking sound and in time eventually started getting louder and was making a rumbling noise. I took front off and seen the one drum roller is broke. How do I replace them and should I replace the idler pulley while I'm doing all this work?
libertyappl
#2 Posted : Monday, October 27, 2008 6:08:03 PM(UTC)
libertyappl
As long as the shaft isn't bent you can probably replace just the rollers. If in doubt replace the other part as well.
Nat
kayakcrzy
#3 Posted : Tuesday, October 28, 2008 3:42:57 AM(UTC)
kayakcrzy
I would replace the idler pully too. To replace the rollers, on the one to the right just cut the nylon triangle clip, that holds the roller in place, and the one on the left, you have to take the 5/16 screw that holds the bracket to the base, and then wiggle the bracket off, and the tab, that holds on the top part will come off with it. Then cut the nylon, triangle clip off that one, and replace. Tom ApplianceEducator.com
robert scholtes
#4 Posted : Tuesday, November 11, 2008 11:02:28 AM(UTC)
robert scholtes
How do put the ner plastic triangle on the roller shaft ?
kayakcrzy
#5 Posted : Tuesday, November 11, 2008 5:06:44 PM(UTC)
kayakcrzy
Just snap it on. Tom ApplianceEducator.com
