The back drum wheel is bent and makes a thumping sound all the time. I have ordered the part so now I need to know how to get at it to replace it. Thanks
Remove the top of the dryer, front panel and the drum then you can access the interior. Nat
Boy, you make that sound easy. If you need some instruction, go to service matters, and down load the whirlpool duet manual. It will tell you how to take off all those conponents. Tom ApplianceEducator.com
