The produce drawer in my side by side GE refrigator is too cold. It does not freeze everything just the stuff at the very bottom.
Thanks in advance Ray
Hi Ray,
What is the temperature in the refrigerator and the freezer?
i think you need to clean evaporator, vacuum clean condenser, after that turn back on, still not right ask Mr Gene pro good luck
Thank's guys. I'll clean everything and see if I can get ahold of a good thermometer to check temps.
I'll reply later with results.
Ray
