2 Pages12>
K Graber
#1 Posted : Tuesday, April 5, 2011 10:34:19 AM(UTC)
K Graber
My electric dryer has no heat and now wont turn back on.
#2 Posted : Tuesday, April 5, 2011 2:03:12 PM(UTC)
What is the end of the model number?
K Graber
#3 Posted : Tuesday, April 5, 2011 2:47:32 PM(UTC)
K Graber
I'm sorry i should've been more specific, the whole model number is mde7658ayw.
Thanks for all your help in advance.
K Graber
#4 Posted : Tuesday, April 5, 2011 5:35:14 PM(UTC)
You have to have a simple multimeter to perform some tests and feel comfortable to work with the live power. If you don't feel comfortable, then you have to hire a pro to do it for you.
Let us know ir you are ready and we will proceed further.
Here are the breakdown diagrams and Replacement parts for MAYTAG MDE7658AYW DRYER- ELE | AppliancePartsPros.com
K Graber
#5 Posted : Tuesday, April 5, 2011 5:43:42 PM(UTC)
K Graber
I have a multimeter and am ready to proceed.
Thank You
K Graber
#6 Posted : Tuesday, April 5, 2011 5:54:58 PM(UTC)
Remove the terminal block cover on the back of the dryer. While the dryer is plugged in, check for 120 VAC between the Red & White wires and the Black & White wires at the terminal block. Check for 240 VAC between the Red & Black wires.
If the voltage is incorrect, then there is some electrical problem outside the dryer.
If the readings are correct, check the door switch for continuity when the door is open and closed.
Open the control panel and check the push-to-start switch for continuity wile the button is depressed.
Post the results.
P.S. Open the breakdown diagrams and scroll down the left side menu to the wiring diagram.
K Graber
#7 Posted : Sunday, April 10, 2011 1:40:53 PM(UTC)
K Graber
Post the results.
the 3 tests you suggested tested fine. the door switch functions properly, theres power to main terminal and the start switch tests good. what would you suggest at this point?
thank you
k graber
K Graber
#8 Posted : Sunday, April 10, 2011 1:46:07 PM(UTC)
K Graber
Post the results.
the tests you suggetsed tested good. theres power to the main terminal, the door switch is functioning properly and the start switch tests good. what would you suggest next?
thank you,
k graber
K Graber
#9 Posted : Sunday, April 10, 2011 1:55:17 PM(UTC)
K Graber
thank you,
k graber
i think i found the problem. the power cord has a burnt wire. do i replace just the power cord or is there more that i should replace also?
thank you,
k graber
#10 Posted : Monday, April 11, 2011 5:42:52 PM(UTC)
Replace the power cord first. Hopefully it will fix it.
- The power cord 3 prong Part number: AP3515739
- The power cord 4 prong Part number: AP3944920
2 Pages12>
