JeffGinGA
#1 Posted : Wednesday, March 30, 2011 12:20:23 PM(UTC)
JeffGinGA
Hello, I posted the below question about a week ago and recieved no response. I called AppliancePros and was told to re-post it. Can someone please help?? Thanks.
Hi. My microwave recently stopped heating. It seems to operate normally, except a buzzing sound, but just doesn't heat. It was manufactured in march 2003. Can you please advise how I should troubleshoot? I am a mechanical engineer - but only average with electronics (don't yet know how to test things like diodes and capacitors). I do have a good multimeter. I'd like to repair it myself if possible.
#2 Posted : Wednesday, March 30, 2011 1:51:39 PM(UTC)
Most likely the magnetron has gone bad and could cause damage to the high voltage diode. Check the high voltage diode as described here. Do not forget to discharge the high voltage capacitor first (the instructions in the above link).
Read more: http://forum.appliancepartspros...smell.html#ixzz1I7csBUrw
http://forum.appliancepartspros.com
- The diode Part number: AP3192533
JeffGinGA
#3 Posted : Tuesday, April 5, 2011 10:38:21 AM(UTC)
JeffGinGA
Thanks Gene! I replaced both of these parts, in under two hours, and now all symptoms are fixed!! Thank you very much!!
-Jeff
#4 Posted : Tuesday, April 5, 2011 12:09:14 PM(UTC)
You are welcome Jeff. I'm glad you were able to fix it.
Thank you for the feedback.
Guest (5)
