allen9258
#1 Posted : Sunday, October 26, 2008 6:32:12 AM(UTC)
allen9258
panasonic microwave will run 3 good seconds and then completely shut off
v2k04
#2 Posted : Monday, October 27, 2008 5:30:15 AM(UTC)
v2k04
Doesw it blow the internal fuse or trip the house breaker after that?
allen9258
#3 Posted : Wednesday, October 29, 2008 5:27:11 AM(UTC)
allen9258
no it does not
v2k04
#4 Posted : Wednesday, October 29, 2008 6:35:09 AM(UTC)
v2k04
Well your model number doesn't come up but If it's an inverter model thats where your problem could lie is a bad invertor
allen9258
#5 Posted : Thursday, October 30, 2008 6:31:29 PM(UTC)
allen9258
just what is an inverter so that i can replace it.
abadfish66
#6 Posted : Thursday, October 30, 2008 11:40:57 PM(UTC)
abadfish66
Sounds like the magnetron is leaking RF. The mag tube comes on 3 seconds after you hit start, that RF hits the board causing it to go blank and then come back on. To test this, you can drop the control panel down and try to heat up some water. If the oven cooks longer than 3 seconds the magnetron needs to be replaced.
allen9258
#7 Posted : Saturday, November 1, 2008 8:02:48 PM(UTC)
allen9258
just what may i ask is RF? And about heating some water u say to drop the control panel down can i just put some water in it and turn it on? and is the magnatron a costly repair.
v2k04
#8 Posted : Sunday, November 2, 2008 6:00:13 AM(UTC)
v2k04
To verify the mag is leaking you really need a leak detector, but you can just replace the mag and find out if that is what is causing it.Mags run anywhere from 70-130 you can find generic mags for less you can basically put any mag into any microwave as long as it mounts.I mentioned the invertor because Panasonics its either the invertor or the mag. The invertor is a circuit board that replaces all the hi voltage on a microwave the cap diode hi voltage transformer etc. 1 board does all that. Generally speaking a mag carries a 5 year warranty but the labor isnt covered and manufacturers wont ship a mag to the customer because of the risk of elec shock. Microwaves usually aren't worth fixing when they go down because you can by them so cheap anymore unless it's a convection or speed cooker like the Advantium. If you spent under 200 for it it's gonna cost more than half that to fix it If a person can fix an appliance for half or less than half of what it cost new it warrants fixing them.
Guest (6)
