Hi, I have fitted a new instant water heater to a Siemens dishwasher model: SE25M851GB/35 and took a picture of the wiring connections before disconnecting the old one. You can guess what's coming... Between then and now I have lost the picture and cannot be sure how to correctly connect it! Can anyone help? I shall try to attach an image of the terminal with the four remaining wires, ready to be attached! I have numbered the wires and labelled the terminals, just in case anyone can offer me any advice and describe which wire should connect to which terminal! I appreciate any advice anyone can offer! Very best regards, Jon B
Please see image attached as described above. Jon B thecaptainsdad attached the following image(s):
Jon,
Do you have the wiring diagram for this dishwasher? This picture does not help much.
Hi Gene, thanks for your reply. I have scoured the web for a service manual but have not been successful. I agree that the image I have posted is completely useless to anyone not very familiar with this particular water heater or dishwasher! My only hope was that I'd be lucky enough for someone on this forum to recognise it and be familiar enough with servicing them to be able to offer some help. It was a bit of a long shot...!
Can you recommend any service manual resources? Many thanks again, Jon B
Can
Jon,
Probably nobody has it but the manufacturer. It's hard to deal with many American brands, so non American are out of question.
Whoops, that should be A1 and A2!
