My Oven has the following problems. No lighted display. Only cook mode that works is Bake. Oven light works. I believe I need to order a Control Panel #AP378762. My question is could the clock AP369030 also be bad because I have do display lights at all? In other words can a bad control panel also cause this oven to have no lighted display?
The clock is the control board. the control panel is just the decorative part. Nat
