I have a small problem I changed out the evaperator fan (that stop working) with new one works O.K. now. But now theirs water dripping from the control housing on the ceiling of the frig its defrosting o k but shouldent the water go some were else ???. the wifes getting P I. thanks phil
The drain is plugged and the water goes through the vent into frig instead of going in pan underneath the hole needs cleard of the restriction
