Fridigaire Gas dryer I have now replaced the flame sensor, the coils, the hi limit thermostat. I have cleaned and checked that there are no obstructions. I removed the vent so that all air is moving freely through the dryer, but I still don't have any damn heat! As before, if I remove the front panel the ignitor glows and the flame ignites for about 1 minute, goes out and won't come back on. With the front panel on the ignitor glows but the flame will not ignite at all. What else could it be? I started this whole repair process to avoid a service call of a couple hundred bucks but now I'm about $75 into this thing in parts alone.
I would check the wires or, maybe spend $30-$40 for a service call to let a professional to diagnose the problem. There is something very unusual.
