blackjackketchum
#1 Posted : Thursday, October 23, 2008 3:56:52 PM(UTC)
blackjackketchum
When you activate the oven using the touchpad the bake lite comes on and the temp shows 100 Deg. and it is flashing. Then the lite becomes steady and the ON lite comes on and stays on for 30 seconds. Then all lites go off. No clicking sound is heard. Sometimes it operates normally and comes up to the set temperature and when this happens you hear a click. Do you know what component I need to replace?:)
#2 Posted : Friday, October 24, 2008 1:45:38 PM(UTC)
Most likely the problem is a bad control board aka a clock.
- The part number for the control board is AP2025165
blackjackketchum
#3 Posted : Saturday, October 25, 2008 6:36:41 AM(UTC)
blackjackketchum
Thanks Gene. I will order the control board and see how that goes. I would just as soon replace the whole built in with a new one but getting one that fits is the problem. So I will try to fix this one. Thanks again.
Jack
