Heres a few more pictures of my relay maybe you guys can look at it and tell me which i need. miichael attached the following image(s):
Michael the replacement is a WR7X5058 contact the parts department here. :)
Originally Posted by: miichael  WR7X5058 replaced by WR7X138 Leave it to GE. :D Also available here.
I think I need the exact same part! At least it looks almost identical. Yes, my model number is correct CB15DPB. My relay fried, literally! Plastic is all blackened and melted! My relay has the following on a paper tag:
43 625-1 1/4 HP BARR 20 Not 100% sure on the "B" A3 8 } 7 }<< These three numbers are @ 90 degrees to the rest 3 } Made in USA
It also has a "GE 36" stamped into the brown plastic.
I noticed this post and I'm hoping that a replacement part is still available ASAP!! Stuff is melting!
Should I also replace the "Guardette 3ARG" while I'm at it?
Or, is the whole compressor fried as well :eek: and that's why the relay went?
Please advise ASAP. Thank you!
Jonathan :rolleyes:
