3 Pages123>
Morris
#1 Posted : Monday, August 13, 2007 3:15:21 PM(UTC)
Morris
Please help!!! One day I turned on one of the elements on my Frigidaire electric stove/cooktop oven and placed a pot on it, when I was done I went to shut off the element as I usually do, but the element did not shut off and stays on in full force unless I unplug the oven from the wall. What do you think is the cause for this? What do I need to replace? I hope someone can help. Thanks in advance, Morris.
moedekoven
#2 Posted : Sunday, October 14, 2007 6:23:18 AM(UTC)
moedekoven
We have the exact same issue with our product and I am wondering if you have had any success getting your stove top repaired.
#3 Posted : Sunday, October 14, 2007 8:24:01 PM(UTC)
Hi moedekoven
In order to provide you with accurate advise I need the complete model number of your range and as much as possible information describing the problem.
pamsch
#4 Posted : Thursday, October 23, 2008 1:15:27 PM(UTC)
pamsch
I was wondering if anyone ever got an answer to this - mine did the same thing today and we have had to shut the breaker off
v2k04
#5 Posted : Thursday, October 23, 2008 1:29:47 PM(UTC)
v2k04
I think the switch went bad.
#6 Posted : Thursday, October 23, 2008 1:36:09 PM(UTC)
pamsch,
What is the complete model number of the unit? Can you be more specific on the problem, please?
pamsch
#7 Posted : Thursday, October 23, 2008 4:48:00 PM(UTC)
pamsch
The complete model number is PLEF398CCC. Naturally our warrant ended in August.
It is the front right side burner which is the one with the smaller element and the bigger element all on one dial.
#8 Posted : Thursday, October 23, 2008 6:25:21 PM(UTC)
Did it show any error code on the LED display?
pamsch
#9 Posted : Friday, October 24, 2008 4:05:44 AM(UTC)
pamsch
No, we were cooking on it and had turned it down to low to simmer and everything was boiling. We took the pan off and the element was still on high. We turned it off and it said HE for hot element like it always does only it never went off.
We turned it the other direction and the big element came on, and that would then turn off but the small element would not turn off at all.
v2k04
#10 Posted : Friday, October 24, 2008 4:15:51 AM(UTC)
v2k04
Replace the switch
Guest (10)
3 Pages123>
