When set for a normal wash I get f followed by h codes when water is starting to fill the washer...i cancel start a few times and finally get the wash done, i have rechecked the water supply filters etc. and all looks good...I get codes only in normal setting not for other wash settings?? any idea what the problem may be??
If it's only doing this in the normal cycle it almsot has to be the CCU(control board) Nat
