I have a Maytag Gemini glass top electric Range. My upper left large element just went out last week. How hard is it to replace it and does any one has a diagram that I can use if this can be done as DIY? Thank you.
In order to provide most accurate advise we need the complete model number of the range. You can find it behind the control panel.
How do I replace the left back burner on the glass top electric range
mompat9,
What is the complete model number of the range?
Originally Posted by: Gene  Hi Gene, I'm also replacing a element for my Maytag MES5875BCS - It's a Slide In Range so the panel and knobs are in front. Would you have a Service Manual and break down diagrams for this particular model?
Here is the Service manual for your range. I can not post the exact diagrams for your model but if you can provide information about parts you need, I'll be glad to support you with the right part numbers. Gene.
Thank you very much Gene! Don't worry about the diagram, I was able to get the part number already. I should be ordering shortly - thanks again for your help and more power to you!
