jlanyon
#1 Posted : Wednesday, October 22, 2008 7:38:04 PM(UTC)
jlanyon
Think that my pump is clogged or broken and want to open up and take a look. Took off screws on sides at bottom(3 on each side) and 2 in the front bottom. What now?
libertyappl
#2 Posted : Wednesday, October 22, 2008 7:52:00 PM(UTC)
libertyappl
Between the top and front panel there are 2 clips about 2 inches in from each corner, release those clips and raise the top enough to get your hand in and knock the front panel down and it should pop off to access the pump.
nat
jlanyon
#3 Posted : Wednesday, October 22, 2008 8:07:35 PM(UTC)
jlanyon
Do I do that with the front screws out at the bottom? That way it will drop down? I was trying to put back together because I thought I was doing it wrong and the side screws are hard to get back in and line up. But I still haven't tried your suggestion yet. I am taking a break from it for right now. Will try again tommorrow.
libertyappl
#4 Posted : Wednesday, October 22, 2008 8:09:27 PM(UTC)
libertyappl
The front screws at the bottom should be the only ones you need to remove.
Nat
jlanyon
#5 Posted : Thursday, October 23, 2008 7:30:31 PM(UTC)
jlanyon
Thanks. Got it working today. Ended up that I had a piece of a drillbit stuck in the pump. Took it out and the washers runs just like new. Thanks again.
