Purchased my Kenmore Elite three or four years ago and it has always worked great. Today, all of a sudden, it won't hold water. Drains out just as fast as it's coming in. Help!
Originally Posted by: bommom  Purchased my Kenmore Elite three or four years ago and it has always worked great. Today, all of a sudden, it won't hold water. Drains out just as fast as it's coming in. Help! Bommom, Based on your post, First thing to look for is: Make sure the drain stand pipe and hose is 36 to 38 inches high from the floor. Make sure the drain hose is not taped or sealed to the standpipe, and that the end is not stuffed too far down, inside the pipe. What you're describing is called a "syphon" problem, and all these checks should solve your problem. If you need more assistance, please supply a proper model number. Thanks, :) :) :)
