The fridge does not dispense water or ice. The fridge is still making ice.
Originally Posted by: Gene Gene The light works as normal. When you push the glass in the light comes on but no ice or water comes out.
Larry, Open the dispenser (the instructions are attached) and check the micro switch, its actuator and wires. Post the results. Gene.
