jhufford
#1 Posted : Tuesday, March 29, 2011 2:42:36 PM(UTC)
jhufford
For model MAH3000AWW, I need to remove the old dispenser lid in order to replace the broken dispenser bezel. Not sure how to get the pins out of the old bezel without breaking it. Any advice would be most appreciated!
Joe / APP Team
#2 Posted : Wednesday, March 30, 2011 6:39:46 AM(UTC)
Joe / APP Team
J,
You'll need an awl(ice pick) or small fine flat blade screwdriver, Youl need to push the 2 pins (one at each end) towards the center of the door until they clear the retainer slot in the bezel, then the door will lift out.
Be careful with the four screws mounting the bezel to the dispenser/top, don't over torque them.
Good Luck,
