tmboyd
#1 Posted : Tuesday, October 21, 2008 1:09:37 PM(UTC)
tmboyd
ONE OF THE FREEZER DOOR TRIM-SHELVES FELL OUT OF THE DOOR. UPON EXAMINATION, THE BRACKETS THAT HOOKED INTO THE SLOTS ON THE DOOR WERE COMPLETELY BROKEN OFF. I COULD NOT FIND THE BROKEN PIECES ANYWHERE. I CONTACTED THIS SITE AND ORDERED PART [FONT='Calibri','sans-serif']AP3042117 (2003128) Trim shelf [/font]
[FONT='Calibri','sans-serif']I HAVE NO IDEA HOW TO INSTALL THIS THING AS THE BRACKETS ARE WIDER THAN THE SLOT OPENINGS ON EITHER SIDE OF THE FREEZER DOOR. THERE IS NOT MUCH GIVE TO THE BRACKETS AND I AM AFRAID TO SQUEEZE THEM TOGETHER OR OTHERWISE MANIPULATE THEM TO TRY AND PUSH THEM INTO THE DOOR. THIS SITE HAS ASSURED ME THIS IS THE CORRECT REPLACEMENT PART.[/font]
[FONT='Calibri','sans-serif'][/font]
[FONT='Calibri','sans-serif']HOW DO I INSTALL THIS WITHOUT BREAKING IT? THANK YOU!![/font]
[FONT='Calibri','sans-serif']TERESA:p [/font]
v2k04
#2 Posted : Tuesday, October 21, 2008 2:11:29 PM(UTC)
v2k04
grasp firmly first slide the lower tab in slot then push up to hook in the upper tab then slide it down so its center you'll figure it out by knowing just one half goes in at a time
