ccraymo
#1 Posted : Monday, October 20, 2008 4:34:13 PM(UTC)
ccraymo
I am hearing a noise...that after pulling the toe plate, sounds like it's coming from the pump motor. Is it possible to have a bearing go out with a dishwasher less than 2 years old? Is this something that can be fixed and has anyone had a similar problem?
#2 Posted : Tuesday, October 21, 2008 11:01:58 AM(UTC)
The first thing I would do is remove the inlet cover inside the dishwasher and check for a foreign object(s) inside the filter sump. This motor is very dependable and usually last much longer.
