When washer was going into spin cycle it started buzzing. Noise is coming from back of washer and it won't stop unless I unplug machine. If I plug machine back in, it stops. If I try to do Drain & Spin, it starts up & then starts buzzing again. I still have water in tub. Is this something a layperson could fix?
Hi Benner, Sounds very strange because there is no parts on the back of the washer which can produce a buzzing. Try to perform troubleshooting tests as described in the Service manual and post the results. Gene.
