dishwasher stuck in rinse cycle, will not cancel, when door is shut goes into 2 minute rinse then stops, shuts off then stars 2 min rinse again please help
I know this reply is coming to you late... but I just had the same problem and found the fix... press your "Normal" button then your "Heated Dry" button alternatively several times (quickly). This will reset the control panel (all lights will come on and then go back off) and allow you to resume normal functioning.
