cw.lewis
#1 Posted : Thursday, July 19, 2007 7:51:38 PM(UTC)
cw.lewis
I have a Whirlpool refrigerator with the freezer on top. Starting about a year ago every so often the drain hole in the rear of the freezer freezes over and causes water to leak into the refrigerator compartment. I then melt the ice and the refrigerator works for a couple of months. Is there a part that is faulty or a permanent solution to this problem?
Adam / APP Team
#2 Posted : Wednesday, July 25, 2007 11:17:22 AM(UTC)
Adam / APP Team
Rank: Administration
Groups: Administrators
Dear cw.lewis,
On some appliances they use a drain trough heater. If you have the model number I can check to see if there is one on it. If you find that only the lower half of the evaporator is freezing up you may have a sealed system problem. If that is the case you will need to seek a licensed technician
Robert Carroll
#3 Posted : Monday, November 16, 2009 5:37:19 PM(UTC)
Robert Carroll
Originally Posted by: Adam / APP Team Go to Quoted Post
Dear cw.lewis,
I have a Kenmore Model #106.9732681 water collects under the bins in bottom. What to do?
