dryer starts to work then all of a sudden stops, is it getting to hot?? it takes hours to dry clothes. please help.:confused:
thanks michelle
A few questions, How long does it run before it shuts down?
Has anything been done to your dryer outlet or electrical system?
Has the cord on the dryer been removed or replaced?
it runs for about 20 min or so. nothing done to the dryer outlet or electric. i also cleaned the vents from the outside nothing really came out. thanks
Originally Posted by: mbellock  it runs for about 20 min or so. nothing done to the dryer outlet or electric. i also cleaned the vents from the outside nothing really came out. thanks Try checking the motor itself. It could be coverd with lint (similar to the pic below) and may simply need to be cleaned.
great thanks i will look at that. one more question how do i get to the motor area???
Please double check your model number. The one you listed dosent seem to be comming up anywhere.
