amshorter
#1 Posted : Monday, October 20, 2008 11:01:58 AM(UTC)
amshorter
This is a side by side and neither side is cooling or freezing at all
libertyappl
#2 Posted : Monday, October 20, 2008 11:13:17 AM(UTC)
libertyappl
Do you hear any fans running, compressor running or any clicking near the compressor?
Nat
amshorter
#3 Posted : Monday, October 20, 2008 11:31:50 AM(UTC)
amshorter
The fan is running well both fans for freezer and fridge every now then there is a click not sure if it's the compressor or not. The compressor is not running.
libertyappl
#4 Posted : Monday, October 20, 2008 11:51:03 AM(UTC)
libertyappl
Unplug the unit, the start relay/over load is probably out. If left plugged in it will burn out the compressor(if not already)
How long has it been doing this?
the first failure suspect is the compressor start device. Remove it from the compressor and shake it. If it rattles then the part is definitely bad and has to be replaced. The run capacitor plugs into the start device and can be used with the new part.
nat
