tom&nathan
#1 Posted : Sunday, October 19, 2008 9:16:22 AM(UTC)
tom&nathan
dryer not heating......... jumped thermal cutoff worked fine...
replaced thermal cutoff worked for about 30 seconds.......
jumped cutoff works fine. can't find what's wrong.....:confused:
#2 Posted : Monday, October 20, 2008 8:50:50 AM(UTC)
Did you replace the high-limit thermostat together with the thermal cut-off?
Looks like there is an air flow restriction, causing overheating. Check the vent from the dryer to the vent outlet and the dryer air ducts and the blower wheel.
Here are the break down diagrams for the Roper dryer Model EL3030WW0
