Chris Laufer
#1 Posted : Monday, October 20, 2008 8:15:04 AM(UTC)
Chris Laufer
Dishwasher runs but at a certain point in the timer, the timer stops and the dishwasher just continues to run for ever.
If I mover it one click it will continue to run in the next few cycles but
then again gets stuck running in another area on the cycle wheel.
So it is getting stuck at two different points on the timer.
I replaced the timer for $150.00 bucks but it still stops at the same
two areas on the timer.
When finished it does have water in the bottom.
thanks for your help in advance.
libertyappl
#2 Posted : Monday, October 20, 2008 8:22:48 AM(UTC)
libertyappl
Where exactly is it stoppiong in the cycle? Can you post your wiring diagram?
Nat
