AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Refrigerator - Water on Floor, Repairing a Clogged Defrost Drain
Hi, I have a GE Side by side refrigerator that water showes under veggi tray on the floor of the frig. I looked it up woth GE site and says: "Some side-by-side models have the defrost drain hole located on the back wall of the freezer, just up from where the floor slopes up to the back, in the center. In some models it is behind a plastic panel held in place by a screw. Remove screw and panel, and the drain hole will be visible.
Flush out the drain hole with a solution of 1 tsp. baking soda and 2 cups of hot tap water in a meat/turkey (bulb) baster. When clear, you will hear water running down into the drain pan below. "
I am not able to located the Defrost drain, can you show me where it is? Thank you, Ali
Originally Posted by: mousavi2011 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi, I have a GE Side by side refrigerator that water showes under veggi tray on the floor of the frig. I looked it up woth GE site and says: "Some side-by-side models have the defrost drain hole located on the back wall of the freezer, just up from where the floor slopes up to the back, in the center. In some models it is behind a plastic panel held in place by a screw. Remove screw and panel, and the drain hole will be visible.
I am not able to located the Defrost drain, can you show me where it is? Thank you, Ali I also wanted to mention that the water is coming slowly from two plastic tubs connected to water tank disp on the back of the frig wall. could it be disconection of tube with water pipe or still coule be the clogged drain causing it.
