Hi everyone,
needs desperately a diagram or repair manual to help diagnose a problem on my Jenn-Air stove.:confused:
I did a oven self cleaning for about 4 hours and problem started after...
I can't use the oven anymore, the control pad works partially and I can't tell if the keypad or clock unit is defective since I have no error code on the display.
The board relay was replaced less than a year ago, and the cable harness contact cleaned. The display is strong and not dimed.
Here are the symptoms : my touchpad on the unit works partially, the control keys for the oven (clean, cancel, broil, bake and convection) seems to partially work, I hear the relay click but the display doesn't change to let me set temperature....after 5 seconds or so relay clicks again (probably cancel the action).
The other half of keypad keys : cook time, timer, clock, and stop time don't work.....no beeps.or change on display.
How can I indentify if the clock unit or the touchpad is the problem ?
regards.....
great forum !
