brokeapp
#1 Posted : Thursday, March 24, 2011 10:40:40 AM(UTC)
brokeapp
Original problem was that bottom oven heating element would not work. Verified element continuity and element was fine. Replaced electronic control and bottom element worked, however once oven reaches temp it does not cycle off. Display shows desired temp but element remains on and continues to heat oven. Replaced oven sensor, still same issue. Thought replacement electronic control may have been bad so replaced it again, twice. Still the same issue with bottom element remaining on. Not sure what to try next??
