How do I remove the top cover of the washer? I want to replace it. Jim
If you will insert a screw driver carefully in the gap between the front and top near the edges you can release clips that hold the front on. After you take it off you can take out the two screws that hold the top to the frame and go from there.
Originally Posted by: sidfink43  If you will insert a screw driver carefully in the gap between the front and top near the edges you can release clips that hold the front on. After you take it off you can take out the two screws that hold the top to the frame and go from there. Thank you very much
remove top cover
(Dryer Repair)
by MikMac
5/13/2009 10:25:34 AM(UTC)
