Noticed over last weekend that fridge not as cool as it should be. Noticed last night that freezer also no longer freezing.
Fan on unit has been running. Have emptied unit and unplugged it for the time being.
Any assistance or direction will be much appreciated.
Joined: 9/10/2007(UTC) Views messages in topic : 9,586
If all the fans are running, pull back panel and check compressor, if not running you probably have a bad start relay on the side of the compressor, please post results.
Changed defrost timer and so far so good.
