The clean light blinks .open the door try running a regular cycle or any other cycle and it won't run.tryed cancel/dain button it drains then the clean but comes back on and continues to flash .any hep would be great.thx.
A heater fault detection program has been added to the electronic control to check for temperature rise and shut down the dishwasher if a temperature rise is not detected. The cycles have been modified to add 8 minutes 45 seconds of fixed heat at the beginning of the main wash. The control looks for the temperatures at the thermistor to increase 4 degrees with cooler (roughly <110° F) inlet water and 2 degrees when there is hot (roughly >110° F) inlet water. If the temperature rise is less than the criteria, then the unit will drain and blink the clean light 7 times. The detection will be ignored if the temperature is out of its normal range, 64° - 160° F, or the door is opened during the fixed heat. Proper incoming water temperature should be between 120° - 140° F. Possible causes of insufficient temperature rise would include wires off at the control, heating element, thermistor, inlet valve, door switch, motor or capacitor, failure of any of the above components or siphoning of the water during fill.
Once a heater fault is detected and the condition resolved the electronic control must be reset by initiating a service diagnostic cycle. NOTE: Using the RAPID ADVANCE CYCLE will cause the blinking LED condition to reoccur because there is insufficient time to heat the water.
Check the product Tech Sheet for the correct cycle sequence.
Nat
How many times does it blink before a pause then the repeated bilnk? Actually it's flshing the answer lol
Clean light bilks. I found a cable that was lose. I reconected, but I do not know how to initiate a service diagnostic service to reset the electronic control. I have a whirlpool GU2700. I will appreciate any help
Hernan.
Your service data sheet is behind the kick panel. Refer to it for the diagnostic turn on procedure. Once entered, hit cancel, dishwasher should now work.
The electronic control has been reset and the dishwhaser is working again thank you richappy for your help.
