Kitched-Aid SuperBa SureCare 3 Speed Whisper Quiet
We start the washer... the water start to flow in and never stop.. until it goes everywhere on the floor.
What is the problem ?
if the water stops flowing when you shut the machine off, look for a pinched pressure switch hose or maybe it has come off the air dome on the side of the tub if both those check good its the switch
