cepearce
#1 Posted : Thursday, October 16, 2008 6:56:32 AM(UTC)
cepearce
How do I remove the platic trim plate on the outside of the freezer door for the water and Ice dispencer. I don't want to break it. I had a spring and some parts fall out and need to access it to figure out what I need to do to fix it.
#2 Posted : Thursday, October 16, 2008 5:32:22 PM(UTC)
Are you talking about the dispenser front cover?
cepearce
#3 Posted : Thursday, October 16, 2008 6:14:12 PM(UTC)
cepearce
Yes, I can't see anywhere that maybe a screw driver would pop it loose.
#4 Posted : Friday, October 17, 2008 3:00:07 PM(UTC)
There are two slots on the bottom of the frame. Insert a screwdriver blade into the slots and gently turn the blade. The cover will snap free at the bottom and can be slid upward.
