wyoming joe
#1 Posted : Wednesday, October 10, 2007 8:24:32 PM(UTC)
wyoming joe
Oven will not light, clicks twice but won't light. Replaced control panel still getting same error code E0 F0. What do I change next? Top burners and clock works.
#2 Posted : Friday, October 12, 2007 1:39:34 AM(UTC)
I would replace your bake igniter if that's your failed area. Click on your model # to order.
wyoming joe
#3 Posted : Monday, October 15, 2007 8:06:20 AM(UTC)
wyoming joe
richappy,
I failed to mention in my first posting that not only does the oven not work but niether does the broiler. I think I need a part that is common to both the broiler and the oven. - Sorry I didn't get all the info out the first time. Could both igniters be bad at the same time?
wyoming joe
#4 Posted : Monday, October 15, 2007 8:54:37 AM(UTC)
I would pull out your service sheet, located on the frame next to the bottom drawer, and see what the error codes mean.
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Whirlpool Oven - Controls Don't Work (Oven Repair (including Ranges and Cooktops))
by Guest 3/25/2024 10:18:22 AM(UTC)
Multiple failures in Whirlpool oven? (Oven Repair (including Ranges and Cooktops))
by Guest 3/22/2024 6:55:50 AM(UTC)
Whirlpool Oven WFE770H0FZ2 (Oven Repair (including Ranges and Cooktops))
by Guest 2/9/2024 7:03:09 AM(UTC)
Whirlpool Oven GBD307PDS7 Shuts down and Upper Blower fan does NOT work (Oven Repair (including Ranges and Cooktops))
by rswilson1844 12/3/2023 11:18:33 AM(UTC)
Whirlpool Oven Cooling Fan (Oven Repair (including Ranges and Cooktops))
by Tfastle 11/21/2023 9:59:51 AM(UTC)
Whirlpool oven - only one heating element? (Oven Repair (including Ranges and Cooktops))
by smithhead 11/3/2023 2:42:01 PM(UTC)
Whirlpool Oven Temperature Low (Oven Repair (including Ranges and Cooktops))
by topthumb 1/23/2023 11:37:05 AM(UTC)
Whirlpool oven WFE505W0HB2 (Oven Repair (including Ranges and Cooktops))
by Guest 1/7/2023 5:44:02 AM(UTC)
Whirlpool oven broil element doesn't go off and code F3 E2 (Oven Repair (including Ranges and Cooktops))
by Right_to_Repair 3/29/2022 1:54:22 PM(UTC)
Whirlpool oven approximately (2006) (Oven Repair (including Ranges and Cooktops))
by Guest 2/28/2022 3:02:09 PM(UTC)
Whirlpool oven shuts off overnight (Oven Repair (including Ranges and Cooktops))
by Guest 4/15/2021 3:53:14 PM(UTC)
Kitchen Aid/whirlpool oven does not light on the first try (Oven Repair (including Ranges and Cooktops))
by Deintinis 11/22/2020 7:42:29 AM(UTC)
Whirlpool oven won’t stay lit (Oven Repair (including Ranges and Cooktops))
by jc0786 11/15/2020 7:11:47 AM(UTC)
Whirlpool Oven - RBS307PVS03 - Fuse for front control (Oven Repair (including Ranges and Cooktops))
by lmagdaleno 11/8/2020 11:50:57 AM(UTC)
