cjohner
#1 Posted : Monday, March 21, 2011 1:49:32 PM(UTC)
cjohner
Dishwasher will not do anything. No lights etc. Have checked and power is coming to the unit and there is power at the swtich/handle. Don't have a wiring diagram so don't know where to go from here.
Applianceaid
#2 Posted : Monday, March 21, 2011 2:34:26 PM(UTC)
Applianceaid
Hello,
It sounds like the thermal fuse on the control board has failed. This is the most common issue on your dishwasher. You would need to ohm the fuse out. The fuse should have continuity. Check the white fuse on the gray control board housing for continuity, you should find your problem.
Appliance & Refrigerator Repair
lou1975
#3 Posted : Friday, April 1, 2011 1:35:56 PM(UTC)
lou1975
How do I change the fuse on my Kenmore dishwasher? My model number is 665.16362301. My dishwasher stopped working at the end of the drain cycle. I know the fuse needs to be changed but I can't find any directions to do that anywhere. Please help. Thanks
