PolishOwl
#1 Posted : Monday, March 21, 2011 10:55:32 AM(UTC)
PolishOwl
The top of my lid switch came off when I lifted the machine front in order to replace the pump. Some of the lid switch parts (spring & flat contact) fell out of the switch. Is there a schematic that shows the parts' location so I can reassemble the switch for all I can find is an outside view of it? Or do I need to replace it at this point? Thank you!
sidfink43
#2 Posted : Wednesday, March 23, 2011 5:40:32 AM(UTC)
sidfink43
Just go ahead and replace it, it is not expensive and that will fix things once and for all.
PolishOwl
#3 Posted : Wednesday, March 23, 2011 7:25:29 PM(UTC)
PolishOwl
Thanks, it's on order!
lid switch problem? (Washer Repair)
by frank dickey 9/6/2009 8:41:48 AM(UTC)
Lid switch problem on Roper washer (Washer Repair)
by Domi22 6/8/2009 4:08:11 AM(UTC)
lid switch problem (Washer Repair)
by Swany 8/25/2008 3:16:13 PM(UTC)
