:confused: Whenever my icemaker fills water runs into the freezer. It just started doing this today but I already have mini icebergs in the freezer compartment. What could be causing this?
Usually it's from the water valve leaking, part # AP4080917. Nat
I would also check to see if the filter is clogged...how long ago was it recently replaced?
