After using the self-cleaning function my oven displayed the F1 code and will not work anything to do with the oven. I unplugged it for an hour and plugged back in with the same result. The cook top works fine. Which of the two components do I need to fix this. It looks like they are separate. Thank you
By looking at your model breakdown your control/clock has the overlay attached. The part # is AP3455542 from this site or 74008098. Nat
Is there an oven temp probe sensor that could be throwing this code if bad? Thank you
There is a sensor in your oven. Here's the breakdown on your unit. Model MER5870AAW Nat
