pjflirty
#1 Posted : 16 years ago
pjflirty
Last night I used the broiler on my Thermador built in oven. Now when I hit bake nothing happens. I can only broil or clean.
I am having this same problem as another poster. And all of a sudden the cooling fan came on by itself(after the oven had cooled) and then shut off after about 5 or 10 min. At the time I had been using bake with a timer. Now it will only broil and self clean.I bought a new element, that wasn't the problem.
Oh model # SMW272
ptlng
#2 Posted : 14 years ago
ptlng
I'm having the same problem. The broil works but not any of the other functions. If I start the oven in convection mode, it shows 100 F and is on preheat, but there's not heat at all. The fan runs, but neither the bottom element or the convection element heats up. If the do broil, the top element and bottom element both heats up. I've check continuity on the elements that they are all good. Not sure what could be causing the problem.
