WOODWORKERPRO1
#1 Posted : Wednesday, October 15, 2008 5:19:20 PM(UTC)
WOODWORKERPRO1
My Amana alw21oraw tub spins freely no matter what setting or cycle. Earlier, during a drain, smoke filled the entire room from the back of the tub. Now, I hear the machine running, yet the tub sits motionless unless I reach in and spin it. What do you think?
rmiljus
#2 Posted : Wednesday, October 15, 2008 6:54:20 PM(UTC)
rmiljus
Looks like the same problem I had on an amana ALW430RAW. The belt burned out due to the brake failing to dis-engage during the drain cycle. The idler pully was damaged too. Also check the pump to make sure it turns freely.
fields
#3 Posted : Wednesday, October 15, 2008 7:25:24 PM(UTC)
fields
Recently I experienced the same problem with my Kenmore. When moving the washer out to check it a small silicone like ring fell out. We took this in and were told it was a motor coupler, which cost 16.00. It took my 17 year old son 20 minutes to repair, wala!!! However, the boy didn't put the hoses tight and now I have a leak. LOL
WOODWORKERPRO1
#4 Posted : Wednesday, October 15, 2008 7:46:06 PM(UTC)
WOODWORKERPRO1
thanks, I will begin there.
libertyappl
#5 Posted : Wednesday, October 15, 2008 8:43:44 PM(UTC)
libertyappl
woodworkerpro1,
Unfortuneately your machine does not have a coupler. although the brake may have hung up and burned the belt into.
Here's the breakdown on you unit.
Model ALW210RAW
Nat
WOODWORKERPRO1
#6 Posted : Friday, October 17, 2008 6:15:04 PM(UTC)
WOODWORKERPRO1
Thanks to all who have replied. As a married man, I chose to do the most expediate and sensible otpion of repair: My wife bought a new one.
peewee
#7 Posted : Monday, February 9, 2009 6:29:30 AM(UTC)
peewee
my wife just went out the door! to sears! i'm draining for salvage instead of fix......... enjoy the new one!
Guest (6)
