AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
Whirlpool microwave shows F2 code and stopped working
I have a over the stove Whirlpool microwave model# 1150XMS-4 that stopped working and a F2 code comes up; I unplug the microwave for a few hour and then plug it back in while holding the cancel button to clear the fault, I have to do this every few days. Can you tell me how I can fix this problem or what part I will need to purchase to resolve this problem. Thank You
This may help: Try to check all the connections first then. F2 - Touch panel failure 1. Unplug microwave oven or disconnect power.
2. Replace touch panel.
3. If problem persists, replace electronic control. 4. Plug in microwave oven or reconnect power Nat
Thank you for the fast reply. I will start shopping around for the parts. Again, thank you.
Josh
Which part did the test show you need I can help you locate parts. Nat
Microwave Repair
