ccjden
#1 Posted : Thursday, March 17, 2011 9:52:26 AM(UTC)
ccjden
top burners work
broiler works
heat warmer drawer works
when I set to pre heat the broiler which is on the inside top of oven lights up
there is no glow what so ever to be seen on the bottom heating element
when I set to bake at 350 or whatever temp, after a few seconds it clicks and goes back to 100 and does not heat up at all, does not show an error code.
could this be a heating element problem or clock timer issue. I was going to order the element seeing as it is not to expensive and go from there but I wanted to ask the experts first, thanks ccjden@hotmail.com
Joe / APP Team
#2 Posted : Friday, March 18, 2011 9:44:27 AM(UTC)
Joe / APP Team
Originally Posted by: ccjden Go to Quoted Post
top burners work
broiler works
CC,
Based on the description & diagnosis
You're correct, start be replacing the glow bar igniter,
I'm sure you'll be fine from there.
Part number: AP2150412
Good Luck,
ccjden
#3 Posted : Saturday, March 19, 2011 9:26:12 AM(UTC)
ccjden
Thanks for the quick reply-ordered part as recommended:).
Joe / APP Team
#4 Posted : Monday, March 21, 2011 6:29:12 AM(UTC)
Joe / APP Team
CC,
Great,
Remember, to let us know how things went, and be careful with that new igniter, they're really fragile.
Good Luck,
ccjden
#5 Posted : Friday, March 25, 2011 6:33:16 AM(UTC)
ccjden
Well, thanks a lot Joe for the great advice and link to part, installed it without to much difficulty and the oven now heats up to the desired temperature just fine, C.J.D.:)
p.s.- inspecting the old igniter did not reveal any cracks or breaks, not sure what went wrong with it..
Joe / APP Team
#6 Posted : Friday, March 25, 2011 7:23:24 AM(UTC)
Joe / APP Team
CCjden,
You did a great job, we're glad your up and going.
You won't always find a damaged spot in the visible portion of the igniter,
They do get weak, just from age, wear and tear(usage) or the circuit fails inside the white porcelain portion of the assembly.
You're quite welcome for the assist, you did the work.
We're happy to be off help.
Good Luck,
Guest (4)
