carl canada
#1 Posted : Tuesday, October 14, 2008 9:30:55 AM(UTC)
carl canada
My refrigerator stop cooling the freezer is work clean vents to no avsil. fsn is running any suggestions? Carl Canada
v2k04
#2 Posted : Tuesday, October 14, 2008 9:39:21 AM(UTC)
v2k04
Verify the compressor is running by removing the back cover you can listen for it but dont be confused by the noise coming off condensor fan motor. If the compressor is running pull the back cover off inside freezer section and look at the frost pattern on evaporator if it is heavily frosted you have a defrost problem, if it has a big ball of ice at the beginning and the rest of the coil is dry you have a leak, restriction or inefficient compressor, in that case you would need a certified tech to repair it and you are looking at a repair of 300-600 dollars..... maybe....
Commercial Refrigerator not working (Refrigerator & Freezer Repair)
by Guest 8/2/2023 5:13:23 PM(UTC)
GE refrigerator not working (Refrigerator & Freezer Repair)
by usert_l 1/25/2018 5:23:15 PM(UTC)
Samsung refrigerator not working (Refrigerator & Freezer Repair)
by smccreary 2/15/2016 7:22:40 AM(UTC)
Kenmore Refrigerator Not Working (Refrigerator & Freezer Repair)
by longbob1108 9/15/2014 6:10:02 AM(UTC)
by razinak123 6/15/2014 6:01:49 AM(UTC)
power surge-- refrigerator not working.. reset button? (Refrigerator & Freezer Repair)
by nashes48 12/26/2013 4:30:18 PM(UTC)
Freezer okay but refrigerator not working (Refrigerator & Freezer Repair)
by dbcasper 11/1/2013 5:52:07 AM(UTC)
GE REfrigerator not working correctly (Refrigerator & Freezer Repair)
by Jdubb1869 6/3/2013 9:47:29 AM(UTC)
by cc.cecile 1/18/2013 6:00:36 AM(UTC)
Freezer/refrigerator Not Working (Refrigerator & Freezer Repair)
by jbbellin 11/22/2012 10:50:57 AM(UTC)
Replaced Compressor Start Device Kit & now refrigerator not working (Refrigerator & Freezer Repair)
by cmj321 8/8/2012 1:40:42 PM(UTC)
Frigidaire Refrigerator Not Working (Refrigerator & Freezer Repair)
by Jim Frederick 8/1/2012 7:59:29 AM(UTC)
GE Adora refrigerator not working (Refrigerator & Freezer Repair)
by ericpg 7/31/2012 5:54:54 AM(UTC)
Amana refrigerator not working but bottom mounted freezer working (Refrigerator & Freezer Repair)
by topperdude 7/10/2012 8:30:30 AM(UTC)
LG Refrigerator Not Working (Refrigerator & Freezer Repair)
by jcastyo 5/14/2012 4:44:25 AM(UTC)
