don419
#1 Posted : Wednesday, October 10, 2007 12:26:23 PM(UTC)
don419
My question is to check the defrost heater can it be done using a contiuity light? This being done with the power off and touching the two plug ends with the light! Also how do you check the thermosat?
Pegi
#2 Posted : Wednesday, October 10, 2007 12:59:25 PM(UTC)
Pegi
Sure, just need to know if it has contuinity or not, check the thermostat the same way, if you are referring to the defrost termination thermostat be sure it is cold, if it is warm it will check bad even if it is good...
mikey0715
#3 Posted : Tuesday, February 26, 2008 7:51:56 PM(UTC)
mikey0715
Thanks for your help,no continuity thru defrost heater on my Sears side by side and saved 20 bucks getting it from you!!:) :) :) :) :)
