Replacement parts for WHIRLPOOL WED6400SW1 29`` ELECTRIC DRYER | AppliancePartsPros.comSee the attachment for the tech sheet.
And here is a service manual
Whirlpool 8178584 Cabrio Dryer Service Manual - ApplianceDigest.com You will have to join the site to get the manual but it is a good site for info for the appliance DIYer.
Probably would not be a bad idea to check the power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Try running the diagnostics to see if an error comes up.
Check the heating coil.
Unplug the unit and remove both wires from the heating coil.
Then measure it with a meter, should be around 10 ohms.
Then measure from each connector to the case, both should be infinite ohms (open).
If not it could be the coil is grounded and is causing problems.
If OK
Check both thermostats with a meter, see the tech sheet.
