Problem: oven doors (both) don't close properly. The hinges were replaced several years ago by a repair service person but the oven still doesn't close properly. I don't know if he replaced the receptacles or not. I want to order new hinges and receptacles but don't want to get the same ones again that don't work. My oven's serial number is 21670364AE which means I guess that I need a series 20 part (which you don't have). Is there any way for me to find out which hinge part is installed in my oven so that I can see if it is the same as the one you are selling? Do you know if I can find out if the correct part exists? Thanks.
Assuming there is not another letter after the model number here is the breakdown and part number pages for your range....if there is another letter this will not be correct... CLICK HERE
